Ok, so this may have a blindingly obvious "No!" as the answer, but I'm learning as I go....
I need to remove the front hub to get at the suspension pieces that need replacing. The description for this in both the Bentley and Haynes manuals is to take off the caliper and then unbolt the outboard bolt on the stub axle to get the hub off, hopefully without leaving anything behind.
My question is this - if I don't want to do any work on the hub (at the moment, at least), wouldn't it be easier to unbolt the inboard bolt on the stub axle and pull off the hub and the axle? The schematics look like it should be feasable. Has anyone tried this or reccommends against it?
Thanks,
Mark
Thanks,
Mark
