Front hub bearings -- which way out?
drooartz
Manual says to drift out the bearings. Which way? Do they go out the end they are closest to (that's my intent at this point). Any tips?
Correct, Drew. The inner portion of the outer bearing should nearly fall out in your hand. Once you clean the grease out of the hub, (usually packed with WAY too much) you can see two little divots above the inner bearing race on the inboard bearing. That's where you want to position your drift to knock the bearing out, tapping on each side alternately. Flip it back over, and you'll see the same feature for the outboard bearing race. Try to lightly tap, side to side, to get the race out as squarely as possible.
Jeff
Thanks Jeff. I did figure that out, in part since as I looked at it, there was really only 1 way for it to go. I've got the disc fronts torn down now, so it's time to start cleaning, and send out the necessary bits for rebuilding.
I'll have lots of questions tomorrow on what needs to be checked/rebuilt/replaced, but one task at a time...
