Finally got my '79 1500 running, well actually, and took I out the other day. Going from an Excursion to a Midget is quite an experience.
Bad news is I am pretty sure the suspension is going to need a rebuild. 40 MPG and over is down right scary. I jump all over the road and the steering is very touchy.
I put new tie rod ends on prior to taking it out. My amature inspection shows I also need new bushings on the trunion, A Arm and sway bar as well as end links. I will replace bearings while I have it apart as well. Before I go with the Major Suspension Rebuild kit, I need some advice on the King Pin rebuild.
Seems to me I saw a reference some where to a reamer and steps to do that but I can't find them now. I searched the whole forum and must be missing it. Is this something I need a machine shop to do or can I do it myself? Do the metal bushings need to be pressed in? I worry about finding a good shop to do this for me.
Any other items I should check out first before I drop $200+ in the kit?
Hi Guest!
