Mark_Gibson
I just finished a frame off resto project on my 70 TR-6, including a rebuild on the engine. New parts included main and rod bearings, new thrust washers, new oil pump, new timing chain and follower, new rings (std size), and new exhaust valves. We miked the cylinders and the wear was minimal, so went with std rings. Engine fires right up and runs fine, but smokes like an insect fogger. We used plenty of rebuild oil when reassenmbling, and the engine has zero miles on it other than running for 15 min or so in the garage. My question is: did we screw something up, or will this go away eventually when the oil rings seat? Compression is OK across the board. I pulled the plugs and several have oil on them, not alot, but some. Thanks for any insight,
Mark
Mark
