19_again
Please see link down below.
If this works you'll be able to see the throttle bar, and at the end of the screwdriver the cotter pin is seen. at that same location is a small brown plate-like peice of metal with a hole as if for a spring, like a throttle return spring. also unseen but at the bottom of the heat shield directly below this device is a location for a fourth spring, the other three being the one for each carb, and another for the choke. I keep asking this question as my engine is slow to return from high rpms, I'll release the gas pedal and it could take a second or possibly two to drop the rpms to idle. This spring if it exists would of course return the throttle to dead idle quicker, IMHO. Thanks for any input.
