bighealeysource
Hey all,
Had a clunking noise from the rear boot area on my BN6 and
thought it could be something loose in the trunk, bad bushings
at the front of the leaf springs. Checked everything and
everything good. Checked the shocks and nuts nice and tight
and then discovered the nuts although tight were about a 1/16
of an inch from making full contact with the shock mount. The
fellow that redid the rear end didn't use lock washers but
the locking nuts ( with nylon inserts) and as a result the unthreaded portion of the bolt would not allow it to snug up
against the shock mount. Put a lock washer on and now it's
completely tight up against the mount and no more clunking.
Figured someone else out there might have similar noises so
be sure to check those shock mounts and the nuts and bolts
to make sure every thing is tight. I just about took everything
else out or apart back there but at least I know now that
there's nothing loose !!!
Regards,
Mike
Regards,
Mike
