RJS
Hi
Beautiful weather in CT this weekend. Trying to the TR out as much as possible. Hope others are too.
Quick question. Twice now in the past 1,000 miles I've experienced a fouling ignition rotor. Symptoms are an engine misfire under load or under more then 1/2 throttle. Symptoms get worse when engine hot, gets better when engine cool.
I can fix it simply by polishing it with a scotch brite pad. When inspecting the rotor after cleaning the edge of the contact is just slightly pitted. I am wondering if this is just a failing rotor which needs replacement or if there is some other condition causing this??
Rotor is about 11 years old with 9,000 miles on it.
Thanks
Bob
PS: I've already ordered a high quality "red" replacement rotor
Thanks
Bob
