Forum Going Down!
Administrator
Boss
Ok folks, in just a short while, THIS forum is going to be closed while I begin the move to the new server. BUT, I have set up a temporary BCF, with most (but not all) of the same forums we have here, jsut so you die hards don't have a stroke /ubbthreads/images/graemlins/devilgrin.gif
The temporary forum is located at:
www.jaguarforum.com/forum
PLEASE Register there with the same forum name you have here (unless you are new and have not registered at the real BCF yet, in which case, register with whatever name you want.
Please understand that this temporary forum is just that - temporary. Once I get the real BCF moved and up and running, then the temp forum will be removed. I'm hoping this will make th etime the BCF is down a little easier to cope with /ubbthreads/images/graemlins/angel.gif
Bye, guys - see you on the other side....
Whew. I was starting to get the shakes, glancing at the clock all the time.
A Jag-u-are forum hey? I'm there. Thanks Basil, good luck with the move.
Registered...but as usual, Janel is soooooooo quick!
(I just talked w/Basil on phone - make sure you REGISTER & use your BCF name.
I am on my way!
