Darrell_Walker
I found a copy of the TSB that talks about the proper way to fold the soft top on a TR4A, but I had some questions:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Release the two clips securing the soft top to the windshield, release the <span style="color: #FF0000">two side draft vent clips</span> from the windshield post, release the three push buttons below the rear side windows and then push the frame work toward the rear approximately half way. [/QUOTE]
What are the "two side draft vent clips"? There is a little tab of material on the front corner, but right now it is riveted to the top. Should this attach to the windscreen somehow?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]When this position is reached make sure to release the <span style="color: #FF0000">two draft vent cups from the second hood stick rail</span>.[/QUOTE]
What are the "draft vent cups"? On my car, there is a flap from the top that is connected to the middle rail, should that be attached with snaps, rather than just riveted?
Thanks!
Thanks!
Hi Guest!
