After pulling the transmission yesterday, inspecting the flywheel showed two areas where the teeth have been worn severely. This is a 59 TR3, #44408, with "shrink to fit" ring gear. I see I can purchase the ring gear for approx. $60, but have no idea of the labor involved to remove the old gear and install the new. Any insight? Alternatively, I can keep an eye out for a good used flywheel and go that direction.
Also, considering I'm also looking to rebuild or replace the starter, is their any advantage to updating to the newer flywheel with bolt-on ring gear and the newer-style starter?
Thanks.
Thanks.
