AUSMHLY
What would be a good product to flush the transmission and overdrive.
Once the car is up on jack stands, drain all the oil.
I've heard you could pour in a couple quarts of ATF or gasoline. Your thoughts on those?
Start the car and slowly run thru all the gears and overdrive.
Drain it and fill with your choice of oil.
Your thoughts?
Your thoughts?
