V
vagt6
Hello, all. In my '74 MK III Midget I've recently noted a very slight leak of what seems to be brake fluid on the rubber floor mat. It's dripping down the clutch pedal from above, originating from a brake master cylinder, possibly.
I took the top cover off the pedal box but saw nothing obvious. This car was restored about 10 years ago and there was plenty of lithium grease on the clevis pin, etc., and it looked clean. There was a little bit of fluid on the dust boot.
Most importantly, neither cylinder fluid level was low, they both looked full with clear fluid.
So, what's the diagnosis? A very slow leak from somewhere. It doesn't appear to leak unless I'm driving (not while sitting still) and then, only a little bit.
Thanks, guys. :thumbsup:
Hi Guest!
