screenprinter
Hi guys and gals. I'd appreciate any and all help with my question.
I'm doing some much needed work to my 67 Sprite The floorpans are pretty much non-existent but the inner sills and the crossmember seem to be in good shape.
I'm pretty good at welding and have a consumer-grade MIG welder using 75/25 argon C02 shielding gas as well as an inexpensive (Northern Tool & Hydraulics) Oxy/Acc. rig
I've done a lot of cosmetic body patching in the past - even replaced the floors in my 70 GT6 - but it has a frame under it. All the talk I hear about door gaps closing up and the entire tub shifting out of square frankly scares me - But the floorpans have been rotten for a while because TPO had tried to get by with chopped strand fiberglass cloth and snot-ball resin right over the rot and the doors seem to function fine.(You should have seen what was entailed in removing the seats)
If done carefully ( that is one side at a time )can the spot welds along the center tunnel and crossmember be cut out and the new floorpan panels (purchased from Moss) offered up from below and welded in place?
I hope somebody out ther has done this and can shed some light on this subject as opinions I have read so far vary widely and run the gamut from just dropping a piece of 18 guage sheet metal in the seat well and one in the footwell and welding it in ( I don't buy that - even a dummy like me knows that the complete panned in floor provides the rigidity for the body ) to the necessity of building a rotisseire to roll the shell over to just rolling the body on it's side ( I don't buy that either - seems like walking all the way around the mountain to take a leak in your neighbor's yard)
But anyway - Thanks in advance for any tips on this subject.
Bob M.
Bob M.
