tony barnhill
Great Pumpkin - R.I.P
I'm replacing the floors in one of my cars...using air nibbler, cutting wheel & tiny air sawzall (2" blade) to cut the old floors out...driver side was no problem - about an hour....passenger side, I was being so careful around the wiring & plumbing underneath; but, I cut about halfway through the brake line!
When you're doing the passenger side, always mark the run of the wiring/plumbing with a felt marker on the floor itself so you stay away from them with your cutting wheel...I know to do that; I know where they are...dummy me, I decided to just 'trust' my knowledge - WRONG!
Also, I've found that running an air nibbler around the outside of the floors right about where the body lip is takes all of 15 minutes to make the major cut...then doing the same around the floor supports breaks everything free in little pieces...the tiny air sawall & cutting wheel are for places where I can't reach with the nibbler.
I'm going to FUSOR the new floors in so all I'll have to do once the old ones are out is clean up the edges of the old floors that I left in place, clean the backs of the new floors & apply FUSOR - a few sheet metal screws to hold the floors down until the glue sets & VOILA! No removing pop rivets; just cutting the old floors away, grinding the edges clean & bare & glue.
But, remember where your plumbing/wiring runs under the car.....now, I get to replace a brake line!
