Flooding
doates
Hi,
Finally got my transmission back in and started it up to adjust the carbs/timing. It started beautifully, but within seconds gas started shooting out of the overflow; tapped the bowl etc. but no change. Took the float out and found that the front float was almost completely full of gasoline - so full that it was difficult to see the air bubble at the top. The rear float is 3/4's full. These are both new (3-4 months) plastic floats and the funny thing is no matter what angle or how hard I shake them nothing will leak out of them.
Has anyone else had this problem? Is there an alternative? Should I drill a hole in them and install a drain plug?
Thanks....Dennis
Had the same issue an it doesn't matter what you do they will fill up again. Get new ones. I don't know from were or who but there is no fixing the old one.
Thanks,
These are from SpitBits so I would like to try another manufacturer maybe brass. Is that a possibility?
On further inspection I found that the glue between the two halves has failed. These are made out of polyethylene and almost nothing sticks to that. My "vinyl welder glue" had dried up so I stuck them back together with Permatex High Tack sealant which acts like good old contact cement. Hopefully, it will hold until I can get new floats.
Any recommendations on what floats to purchase would be greatly appreciated.
Thanks Again...Dennis
