I have rebuilt the carbs and did a tune up on my '69. The car has the original carbs with no mixture adjustment. The car was running fine and I was tweaking the timing.
The engine sputtered and quit and would not start back. I put the timing back where I started and it still would not start. I made all the normal checks (spark and gas to the carbs, plugs etc). The plugs seemed to be fouled with gas. I removed the carbs and there was there was gas at the intake manifold. I removed the carbs and reset the floats. (they seemed to be close)
The engine had not been run for about a month after the carbs were rebuilt and installed. I am going to install the carbs this week and try it again.
Any other suggestions?
Thanks, Pete
Thanks, Pete
