dklawson
My car's recent running problems turned out to be a hung float valve. This pair of valves is virtually brand new so it's not an age or wear issue. There are no deposits in, on, or around the seats to explain why one of the two valves stuck closed.
I installed these stock float valves to replace a pair of Grose Jets that I suspected were leaking. I'm not really interested in re-installing the Grose Jets.
My question is historical and application based. In my youth I remember working on a car (God knows which one) where the moving part of the float valve was connected to the float arm by a music wire clip. When the float fell the needle was pulled off its seat. The needle valves in my SUs have a machined groove for such a clip... but I don't ever remember seeing them on LBCs. Do any of you remember working on carbs that had the type of clip I'm talking about? I'm thinking about forming up some clips of my own but I'd like to hear from you guys about any pros or cons you can think of about this.
