Flexible fuel lines
Rays
Member
My 1967 MGB has developed leak from the short fuel line (#12) between the Tee (#11) and the rear carb. I was going to buy an new fuel line, but should I also go ahead and replace the other, longer flexible fuel lines from the rigid fuel line and to the front carb (#13 and 10)?
Also, I can't find any fuel filter from the fuel pump all the way to the front carbs. I guess there isn't one.
There's a fuel filter attached to the fuel pickup inside the gas tank...However, because of age, most of us add a clear fuel filter at the end of the hard line right before the carbs...think about flexible/soft lines this way: if you don't know how old they are & 1 has already started leaking, change them all is my creedo.....at least that way I have a base line in my records.
