A little help please.
I have all the electric components installed in my restoration, other than those directly associated with the motor. In trying out the flashers I discovered that the left turn signal works great front and rear. The right front and rear lamps do not flash when the turn signal is applied.
I am using the orginal flasher canister and a new flasher relay. When the turn signal is turned on in either direction I do hear one click at the relay, though the click for the right non-working side isn't quite as crisp as the left. The flasher canister continues to click when the left signal is applied, but no clicking at the canister for right turns.
I replaced the original flasher canister with a new one and I got nothing in either direction??? I may have it hooked up improperly. The original canister terminals are marked as in the manual: B - Green, L - Green/Brown and P - light green. The new canister terminals are marked P, X and L. Can someone tell me which color wires should go to which terminal on the new canister so that I can check myself?
I checked the workshop manual and read about adjusting the flasher relay so I thought I would check things out in the box - whoops! New box is all electronic - circuit board inside. Are there no adjustments possible on this electronic version of the flasher relay?
Is my problem the canister?, or, should I look for another culprit? Thanks for any help offered.
Lin
1960 BT7 in restoration
1959 Bugeye
Lin
1959 Bugeye
