Hello again everyone,
I received this message from the guy helping me restore my midget.
"The MG is running and starting to sound good. Eric had another good day. He installed a set of points and condenser first thing and no fire. Upon checking we had no fire to coil. hot wired coil and still no spark. Then he inspected the distributor and the internal wire had a break in it, He then made a jump wire inside the distributor and then had fire . Upon priming carbs and having good oil pressure he got it to fire. He filled the cooling system, adjusted the carbs, adjusted timing and basically spent the afternoon adjusting and running the engine. Getting it running along with other things we had a good day. As far as parts we feel the distributor is already causing problems, the internal wire , the base not letting fire thru points etc. Eric had to jump wire inside the distributor to get it to run. We think you need to replace the original point distributor with an electronic unit. There is a flame thrower distributor part no 10-518 in Victoria British and we also need a coil either part no 10-538 or 10-539. "
He is wanting to use a new Flame-Thrower Electronic distributor, and i'm not sure if this is a good idea vs using an original one. Anyone have any thoughts? I sure do apreciate everyones opinion here, thanks
