germanmichel
Hello @ all,
like written in the subject line,does anyone know,how is the outer tube end(around of the steering shaft)fix in the steering box ?
I talk about a steering unit of a 1960/BT7. For me it looks like it was... a tight fit. But now it have play and it is easy to remove. On the outside diameter of the tube it is tin lead solder, i think it is not original. So what is the original best solution to get it fix and sealed ? No manual show this area. I mean the area under the item bubble 5
https://www.limora.com/index/lang-1/lkz-1...oesserungtop=30
I think about different solutions : hard soldering , tight fit with expanding and turning the tube end, but what was the original solution ?
Thank you all from good old and cold Germany
Michel
Michel
