Fitment of Rally Harness
BrianU
I have purchased a pair of 4 point Rally Harnesses, Eye bolts and backing plates for my 100/6, fitment information seems difficult to track down. Where should I fit the Eye bolts and do I need to weld the plates in place.
I was also intrested in finding the proper mounting points for a 3 point inertia reel seat belt. In your case maybe you could contact one of the roadrace teams and they could give you the info. Probably you could find one on yahoo!
Good luck. Bob G
bottom mounts - go look under a few GM's or Fords, back mounts are the hard part, mine are through sheetmetal bulkhead separating cockpit from trunk with large "washers" behind, idea being it spreads the load to the few spot welds/rivets holding the bulkhead in place, or its put solid anchor points in, weld/bolt?
I would think it would be best to have the shoulder belts mounted as high as possible to shoulder height, is this correct? It may be easier to mount these in a 2 seater than a four seater. Any suggestions appreciated.
