Air, fuel, compression, and spark. That's all it really takes, right? I thought I had everything squared away, but after half a can of starter fluid, all I have to show for the starting effort is a tailpipe full of ether.
I had a new/old fuel pump that came with the car, and it appropriately sucked up fuel from the plastic gas can and pushed it into the carb reservoirs. I'm not familiar with this old type of pump, but it seemed to shut down after the bowls were full up. Does that sound right? Anyway, there's fuel in the carbs. Whether that fuel is being aspirated into the manifold and cylinders is another question. There could very well be plugged passages, but shouldn't the starter fluid have resulted in more than a rare "pop"?
There is spark on all cylinders as proven by my inline spark checker light bulb. Is it timed correctly? I don't know for sure.
Is there compression? I think so. I'll check with a compression tester later.
I think I'll pull the carbs and put them through a solvent dip. I welcome any further suggestions.
Hi Guest!
