SD Bugeye
So I was out for a drive a few weeks ago and had a scary thing happen.
running down the hiway at speed and all of a sudden I smell raw gas.
pulled over and see that there is gas pouring from the over flow of the rear carburetor
kind a scary moment with the header at temp and gas poring over it
had the issue fixed in a few minutes but the visual of the car in flames lingered .
so I found the answer to having an extinguisher that is small doesn’t leak doesn’t take up a bunch of room and could be placed in a location that is easy to get to in a panic
can you see it?
https://elementfire.com/products/element-e50
can you see it?
