NO foolish move, Paul!! I have a 24 port panel and a 24 port switch here. All rooms hard wired with at least two drops. I did all th' cable rat stuff over two years ago. Overkill? feh. It'll be a selling feature for th' place when it goes on th' block. Only home in the subdivision *properly* wired for the 21st century.
A funny: I had Verizon FiOS installer put the new stuff all in one place, had a drop right at the spot for the modem. Told him this would be his easiest install. He asked where that blue cable went, so I show'd 'im. Racked panel, switch,the firewall box and three machines in one room. Workstations in the others... he shook his head and said something like: "I don't know anything about this network stuff. Wow."
As soon as the modem was up, I stuffed a dedicated run into the thing and had connectivity thru the firewall box on all the workstations. He tried to shove the "value added" warez onto a Linux machine from a thumb drive... no joy. I asked for the default username/password of the modem and told him I'd be fine from there. Whole deal took under an hour. It amused me.
I cut the WiFi OFF at the modem. Have a separate Linksys WiFi router INSIDE the firewall I can turn on and off when I want. Hammock in th' backyard jungle, a CAB and a laptop. Life is GOOD. :wink:
