Hi Marc,
The best I could make out was that the parent metal (Birmabright) is supposedly NS4. The general recommendation seems to be to weld it with 5356 rods. Search for welding birmabright as there is a fair bit about it on Landrover forums.
I had a bit of a debacle TIG welding my rear shroud. A friend here is a very good welder so I got him to do the welding which he had quite some trouble with due to dirt in the metal. The main issue is that wherever you weld will crack right afterwards if it is ground flat. After a few attempts at the weld, grind, crack game, Steve left his welder with me and just said keep welding until it stops cracking. The technique I found to be most effective was to lay a fairly large bead on top and melt it down to just above flush, then turn the shroud over and grind out most of what had come through but leave a smooth mound about twice the parent metal thickness. If there is still a depression or line down the middle on either side after grinding then it will crack there shortly.
Definitely need a foot pedal on the welder and a stainless steel wire brush in a battery drill to scour the metal right down until it is completely shiny. Hand wire brushing was nowhere near effective at removing all traces of oxidisation.
Andy.
