regularman
When a fender is installed correctly, How much gap should thier be between the fender and the cockpit and how much gap in the radius between fender and rocker panel? Mine has about 3/16" on the former and 1/8" on the latter. Also should the fender be exactly flush with the rocker at the bottom and the A pillar on the side? My fender sticks out about 1/16" along the radius and a bit more on the side at the A pillar. I worked on the A pillar and replaced the bottom hinge area so I will have to fix that some I know.
