Jim_Gruber
So the UPS lady showed up with a 6' long mailing tube containing 2 new 66" long fender beads for Bugsy II. The bottom of The T that fits between hood and fender is close to 3/4" long. I need to trim the bottom of the T down to about 1/4" long so I can glue in place. Have for the most part prepped the seams by cutting a groove approx 1/4" deep and cutting out the rusted in center section of the T. Still will need some work to fit but I'm getting there. Couple of questions.
1) Others have used an angle grinder with a cutting blade or a Dremel Tool to trim the bead down. Was also considering how to set up some sort of jig on the band saw that I could push in the almost 6' long section of T and out would come a neatly trimmed fender bead. Sounds great but I think I have a whole lot less control and risk having the bandsaw twist my nice fender bead into a pretzel. Looking for advice from the group on trimming the fender bead down to size. Band Saw, Angle Grinder with a Thin Cutting Blade or Dremel Tool with a cutting blade. Angle Grinder with really thin blade has the mass and the power to quickly cut.
2) Ideas on how to securely hold the fender bead for trimming but at the same time not bend or distort it would be appreciated. Hmmm two 36" pieces of angle iron clamped together in my Workmate with T in the middle, cut off flush with angle grinder held parallel to the angle iron. More thought needed on that idea.
3) Bead appears to be stainless. Advice on painting or treating before it gets glued into the cavity between fender and hood?
4) Thinking panel adhesive as bonding agent. I think it's 3M now offering in a twin tube applicator that does not need a special gun to apply. I do have someone on this list who offered to lend me their special gun for applying the other panel adhesive product. Thanks in advance if I decide to go that way.
5) Slot will be treated with Rust Converter before bonding agent is added. Hard to get in there with cutting wheel to remove rust and old bead but not cut through the hood to fender welds. As much rust as I can reach has been cut/ground out. But stuff at the very bottom of gap cannot be reached without totally removing fenders. Any thoughts. Can't see what may be in there bit I'll assume there is more rust I cannot reach.
Hi Guest!
