After 35 years of restoring/running TR's I am now running a BT7 mk1 as well as two TR's, (TR3A & TR4A). The Healey has been restored before I bought it and has a fault in the control head, I have rebuilt similar TR control heads for early TR's but would like to know if anyone has had a similar fault before I take it apart as either this may not be necassary or I may not spot the fault when it is apart.
The problem is that when either turning right or going around a reasonably tight righthand bend the left hand indicator comes on when straightening the wheel. The opposite does not occur when turning left.
I have noticed that the indicator level is reasonably tight against the side of it's slot furthest from the steering wheel, it springs back when it is pushed down, Could it just be friction internally dragging it round?
Hi Guest!
