Failed State inspection-tie-rod end? Need help
jbuffalo
1978 Mg Midget-just got it running and stopping right. It failed the NY state inspection. The front wheels move side ways moving the tie-rod-one is very loose. The garage was not clear about what to do or how to inspect the steering. After looking it up at home it looks like the tie-rod inner ball joint assembly. How big of a job is this. What parts do I buy. Need help and suggestions.thanks Jim
Sounds like a front end rebuild coming up. More than likely far more than tie rod ends. Yoo are about to receive a multitude of answers.
Hi Jim,
If you put it up on jack stands, get under it, and have someone shake the tire at 3 and 9 o'clock, you should be able to see play at either the outer end or the inner end of the tie rod (or both ends!)
Not a bad job... Outers (tie rod ends) just involve splitting the end from the steering arm, unscrewing the existing end and screwing on a new one. Measure / adjust toe-in afterward.
The inners aren't horrible either, disassemble and reassemble. The hardest part will be probably be stretching the new rubber gaiter back onto the rack, which can be a real pain in the... rear end. The inner joint (ball housing) can be tightened / adjusted, see John Twist's video for a quick demo. https://www.youtube.com/watch?v=zQt-u-frkJs
Mot a big job at all, couple of hours. Check the Moss Catalog for an exploded view and parts.
See Tony for parts.
not a big job - and not too expensive either
As Jim G. says, *if* the front end has been neglected, you may find many other things need replacing as well. Bearings. Shocks. A-arm and trunnion bushings, the threaded pin that connects the A-arm to the kingpin, and the kingpin itself. All of them can and do wear, usually as a result of lack of lubrification. Moss and VB make various kits, but all together the parts can easily add up to $1K.
Do your wheels lean in at the top, when viewed from the front? Do the inner edges of your front tires wear more than the outer edge? Usually a good sign of an impending front-end rebuild.
Duncan is right but take a deep breath - that's a worst case scenario - no single part is difficult - start with the tie rod ends/inners and see where you get from there.
JP
PS I can probably slide down and give you a hand especially if you're available on a weekday - Waterloo is pretty close and my wife can hit DSW shoes
Thanks Guys, especially John-Peter-my wife likes Dsw shoes too much. I went back to the shop-there was a new fellow on the front desk-very new 3 days-everything was confusing. Anyway I brought my Vic Br cat. and Moss and the long time older mechanic found their MG repair book and it went in today for the repair. Jim
great! let us know how it goes
