My TR3A kit came with a new wiring harness. Probable from British Wiring manufactured in the late 1990.
I have been installing it as I go and have found what appears to be an extra wire. The Green/Brown from the flasher unit ends up on the passenger side where the horn and head light connections are made. Then there are 2 Green/Brown wires going from that point to the same point on the driver side.
I will connect the flasher wire to one of the wires that go to the other side where it will be connected to the wires that go up to the indicator switch. That will leave one wire unused.
David
David
