BRSLimited
Have you ever wondered why the Haynes manuals say to leave transmission work to a qualified person? Well I just had a Spit 6 come in with the owner complaining about 3rd gear. I start the car up in neutral and you would not believe the noise coming from the transmission. I could actually put it in 3rd gear without touching the clutch and the car would not move an inch and the trans actually got quieter. Go to pull it in the shop and the car moves about 50' under it's own power and the trans locks up. Pulled it out and pulled the cover. I find 6 teeth off of 3rd gear laying in the bottom of the gearbox, laygear is shot, first and high gear teeth are worn to a sharp point, input shaft bearing is shot, and the input shaft can wiggle nearly a quarter of an inch. The main shaft has aprox .350 of end play in it. Someone appearently had it apart to put new syncro rings in it as they are nice and shiny new (and now junk). On the plus side they did remember to fill it with (of all things) ATF after putting it in. Just goes to show you. Never under-estimate the power of human stupidity.
