regularman
Drove my midget to work at 0500 and it was cold on the ears. Down the interstate and then down the highway and just as I ma getting near work, I feel the engine hunch and die away and then come back. Then its all crazy and I pull the choke out and it smooths out some and I manage to get to work and into a parking space. Its still dark and I think to myself I will go out and check it during a lunch break or whatever. All that morning I think it over and I think it must be that filter in the DGV stopped up and starving the carb again. I go out during lunch and clean the filter and it has some it it but not that bad. I try to start it and it will only barely run with the choke on. I finally take the top off the carb in the parking lot and check it over and it all looks ok. Whew, I put it back together and still barely it will run. I just quit and think things through, upset now. I decide to check fuel pump, take the line loose and turn the switch on, plenty of fuel and pressure. Then I just look down the carb and work the throttle. The force pump is shooting out gas, I know it is getting gas, then what the heck! I start it and it runs like hades and then quits and I cannot restart. Lunch break is over, no food and no running midget :madder: I think it over for the rest of the day. It rains but not hard with just the tonneau on but not hard so I don't put the top up (which I normally would have done but still upset). After work I decide to check the basics. Clean the points and condenser. I sand clean and do all that and then check spark, nothing. I do it all again and still nothing. Whew. I get my meter out and the wiring diagram in the manual and check the coil for +12 when switch is on, nothing. I check wiring connectors under the dash, look good. I check fuse that feeds coil, looks and checks fine. Finally I pull on the + wore going into the coil and find the wire is broken but still up under the sleeve of the terminal. All the strands of the wire had broken and it was making intermittent contact. I stripped this wire and put on a new terminal and it fired right up and I then had to put the carb idle mixture screw back where I had fiddled with it. Nothing wrong with the carb at all, but somehow pulling the choke out and having a richer mixture allowed it to run with that poor connection where normally it wouldn't. That is one to remember. At home now and time for a beer.
