Westfield_XI
I got the Summit crankcase evacuation system installed and tested yesterday. It seems to pull a good vacuum at idle, in fact it is pulling oil up the hose and into the exhaust. No more mosquitos in my neighborhood, but the neighbors were a bit alarmed!
I have a port on the fuel pump pad connected to the vent tube on the valve cover and then on to the evacu-sump unit. It looks like all will be well if I just install an air-oil separator in the line. Meanwhile I am capping the vacuum device until the catch bottle arrives.
Bottom line, the Summit kit works as advertised, needs a separator, but I cannot comment on fitting to a Spridget since my car is very different.
Hi Guest!
