I've got a two year old battery with 5 great cells and one that is 35 points weaker than all the rest. If I read my Spec. Gravity Tester correctly, that cell is bad.
Can I fix it by adding a mixture of dissolved Epsom Salt and Hot Distilled Water into that cell?
I've read that all cells could be reconditioned in this manner, but first by draining the solution to make room for at least 1/2 qt of water and dissolved Epsom Salt. Wouldn't that drain off all the critical sulphuric acid?
