Tried to start car and engine turned over but never fired. The last time the car was driven was two weeks ago and the car had plenty of power. Compression for cylinder two thru four is 189 and cylinder one is 124. With hose disconnected from front carb, gas was pumpded when engine cranked. Removed both float bowls which contained fuel and appeared to be at the same level. On the front bowl, I pressed the float down and gas came out the jet. Why are my plugs not getting covered with fuel after extensive cranking?
