Although a slight down angle seems intuitively correct, I'm going to guess that the engine/transmission center line is parallel with the horizontal plane of the forward part of the frame, which is straight. I can't prove it but I can't find any evidence to the contrary and that certainly doesn't mean that I'm right. The Original Service Manual does show that the aft flat frame section appears to sit lower aft than forward, .19 inches in 29 from the frame plan. If my math is correct, that's about 1/2 degree, which would tilt the engine the same 1/2 degree.
Not much of an answer, I know. Perhaps someone who knows will chime in (or correct the math).
Tom
