Jeepster
I am still struggling to get my engine running and sort out the timing issue. I did tag onto the end of a previous post but thought I better start my own.
Some weeks back I had a fuel blockage which was traced to the tank sealer in the fuel tank coming free and blocking the feed pipe. So installed new tank and problem solved.
Then whilst on a 100 mile round trip drive the engine started to lose responsiveness and went very flat at mid revs. I managed to limp home and decided that it might be ignition related. I had planned to install new cap and leads etc so thought this a good place to start.
Installed new dis cap, rotor arm, coil, leads, plugs and electronic ignition module.
Since installing the elec ignition, I was told to expect that the engine would need re timing? When all the above was fitted the engine would barely run so I turned the distributor to try and improve tickover. This did improve slightly but the distributor has come to the end of its adjustment before I can advance/retard enough to even start on fine tuning the ignition.
How can I get the distributor to give more adjustment? It won't rotate any further clockwise at the moment.
There is a possibility that the original fault was a fuel blockage in the carbs from maybe some debris in the new tank? I am unable to investigate that until the engine runs.
I have. Fuel filter installed before the fuel pump.
Any help appreciated as I am at a dead end.
