1976 1500.
Webber carb. Stock fuel pump. I have worked on neither.
I have had enough success with this car to be able to get some road time - but not a lot. I have been having some fuel system problems after rebuilding the cooling system.
The cooling system - the fan ate a hole in the radiator. That plus some previous work has resuluted in a new radiator, fan clutch, all hoses, and water pump - pretty much every thing but the thermostat. Prior to that work, the temp gauge was reading 160-170 degrees. Following the work it is reading 180-190. The outside air temp has gone from around 80 to around 100 (SE Arizona), which might account for a shift in the coolant temp.
Simultaneous with the coolant system repairs, a problem has occurred with the fuel system. Once the engine has heated up, my idle drops below stall speed and if in gear the engine acts as if it being starved for gas - I get major surges in power, several seconds on and several seconds off.
I might add that I have not yet taken it far from home and as soon as this starts to happen, I return home. AS SUCH, I cannot be certain that the engine temp has stabilized out to the 180-190 mark. However, the temp rise looks normal, slow and steady all the way from 'cold', with a slow down as it goes higher.
Is the temp rise likely a problem, or linked to the outside air temp? If a problem, what might it be?
And what might be causing the fuel problem?
Hoping for an answer,
Bob
Bob
