If you are going to rebuild it and have the room, I would take it apart and grease all the parts where they touch and run against each other. Then wrap each part in a oil covered cloth. It takes a bit more room to store it, keep the block off the ground and put it up on treated wood, every part in the valve train should be marked as to which rod and lifter go together, unless you are going to lite weight on the rebuild. Wayne
