My 1971 TR6 has an intermittent stalling problem. Sometimes when coming to a stop at a traffic light the idle suddenly becomes very rough. It drops off from normal idle and will stall out if I do not hit the gas pedal several times. Usually this only lasts 10-15 seconds at which time the idle usually corrects itself. I have the stock dual- zeniths which have been rebuilt. I have already repaired several vacuum leaks and had the distributor rebuilt. I'm not sure if it is still leaking vacuum or fuel starving. Any suggestions?
