MGB Engine sputter upon acceleration
Snads76
1969 MGB Rdstr sputtering upon acceleration. Engine holds steady idle set a 1000rpm. Sputtering occurs when engine is reved to clear. Too rich fuel mixture? Thanks in advance for your help
Welcome to BCF. Many possible causes of sputter/miss on acceleration:
I'd check (1) fuel flow and fuel levels in carb bowls, (2) crud/sediment in fuel filter(s), (3) ignition (spark plug gap, timing, failing coil and/or condenser, (4) distributor rotor and wires.
How long have you had the car? When did the problem first start? Any changes made just before the problem started?
Tom M.
Tom M.
And check the dashpot oil.
