bluemiata90
Should I rebuild the engine or just clean it up and add new externals(waterpump, generator, hoses, etc). I just recently purchased this 61 TR3 and after cleaning the gas tank, changing the oil and cleaning the carbs, the engine started up. Very little smoke when first started and it cleared up almost immediately. Did a compression test, 120 psi across all 4 cylinders. The vehicle has 71000 on the odometer, supposedly original miles. My question is are 71000 miles alot of miles for a triumph TR3?. I never really drove this TR3 around and I already pulled the engine and trans. to clean up the engine bay and engine. A rebuilt engine will obviously be the most reliable way to go, but also much more expensive. If 71000 miles is high for these engines then I guess I'll have to do it. Feedback is needed in this situation. /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/confused.gif
