I just recently disassembled my 1500 engine. I thought when I removed the pistons and rods that the numbered order marked on the rods was 1,2,4,3 starting from the front. Is that possible? Does it start from number 1 at the front? I probably just mixed them up knowing me. It is all going to the machine shop anyway but I am just curious. Also, my cam has a grove in it on the fuel pump lobe. Is that common or should I purchase another camshaft? The rest of the cam is excellent. Could that be from a wrong style pump or maybe not using the spacer? Thanks in advance.
