BUCKEYE_BOB
Member
Today I was looking around the engine compartment and noticed that i had several wires that the insulation is cracked. I was going to start checking connections. I noticed that the insulation is real brittle and cracks easily. Now I'm wondering if I should just replace the Engine harness. I do not want a lot of shorts. I've changed or repaired harnesses on Honda(s), so a MG can't be any harder. Does Moss and VB supply good harnesses? Any suggestions would be helpful. Thanks Bob
