Engine/gearbox out..now time to install Taylor box
VelodromeRacer
Here are a few pictures of the gravity machine...
Engine out
Bugeye2
Bugeye3
Now putting together the line set for the clutch..
YOu go Doug, what did you do about a Flywheel for the Tilton Clutch, did you have to drill it for your 8 bolt crank?
Hap,
I am waiting for the flywheel from Rick. He said it was drilled for the standard 4 bolt setup though. I am looking at making a template when it arrives and having the other 4 holes drilled.
I received my hardware for the clutch line routing and have a ss hose for the line into the gearbox.
I'll post more photos when I get that done!
I also "had" to add a plaque for the dash from an airplane that states "No Intentional Spins"
