Hi folks ,
Does anyone have linear measurements for the engine with usual components attached? Or, if there is a document like the frame "blueprint" you can refer me to, I would appreciate it. I am looking for things like height from bottom of oil pan at lowest point to the top of the rocker cover (or the vent "T" pipe on the cover), depth from fan center to engine backplate, depth from fan center to end of the gearbox, width of the block and width from the air cleaners to the distributor (widest point of the assembly).
Thanks for sharing if someone has this information.
Lin
1960 BT7 "The Bloody Beast"
1959 AN5 Bugeye
Lin
1959 AN5 Bugeye
