PatGalvin
As I'm slowly getting this car back together, I discovered that the engine cross tube (between the front suspension towers) was so tight - very difficult to install. I needed to install this so that I could fit the radiator and the new Spal electric fan. The fan needs to be installed high above the tube or it fouls the tube.
I pounded on this tube mercilessly but it just would not fit between the shock towers. I didn't want to head down to Harbor Freight and plunk down a hundred bucks on a porta-power hydraulic ram unit so I grabbed some extra pipe and angle iron and welded up an assembly that would allow a helper to separate the towers while I installed the cross tube.
It worked pretty well, although it required my wife and her friend to pull on it to separate the towers. Two hours later, I had the tube installed.
Before you all have a chuckle at my expense, the masking tape was simply to protect the frame paint, not for added strength! hah!
pat
pat
