yon_pie_eater
Hello All,
Every twelve months or so, I usually take the 3000 for a morning blast up the Autoroute for about six or seven miles to clear out her chest a bit....So this week I ran her up to about 95mph, and sat there wind in hair, sailing past the moderns, then after about 4 miles there was a nasty cough from the engine (no rattling or bangs...just a cutting out) accompanied by an oily whiff (not that chilling head-gasket watery oily smell)..the car more or less died on me, and the oil pressure dropped from its normal 60 to about 30-odd. I coasted to the side of the road, kept her running, then limped off at the next exit.
I stopped and had a look...head looked ok, no oil in water, no mayonaise in oil, but I noticed some dripping from under the bellhousing. I checked the oil level, then started up the engine and took her home.
The engine is now running with around 10lb less pressure than normal (usually 50-65, now 40 to 55), and at the end of a run this morning there was a small cup-full of engine oil (not the crystal clear stuff from the 'box) on the floor. Apart from the dripping oil, and the oil pressure drop, everything seems ok..no noises or significant drops in power...
Am I right in assuming that the extended fast run may have blown the rear crank seal?..but the oil pressure drop?...
Thanks for any advice on what it could be
Andy
Andy
Hi Guest!
