Hi Guys,
I have been diligently working on my BJ8 and have the following problem. I am very frustrated so any help would be appreciated.
The car only has 38,000 miles (??). The SU's have been totally rebuilt. The PO had fitted a Petronix ignition.
The car stars great and runs smooth until about 2,500 rpms's. It then exhibits a "crack" sound like a backfire. If you increase the throttle slowly, it doesn't occur, but if you give it power quickly, it stumbles and I get that sound at about 2,500 rpm's.
Here's what I've tried so far:
- Checked timing and it seems fine.
- Pressurized each cylinder and check valve seating - perfect.
- Check rocker adjustment with only minor changes.
- Check compression in each cylinder - fine
- Changed from Champion plugs gapped at .025 to NGK gapped at .030 to see if there was a difference - no change.
HELP!!!!!!!!!!!!!, before I blow my brains out.
